configure snmpv3 delete target-params
configure snmpv3 delete target-params [{[[hex hex_param_name] | param_name]} | all]
Description
Deletes SNMPv3 target parameters.
Syntax Description
hex_param_name Specifies the parameter name associated with the target. The value is to be supplied as a colon separated string of hex octets.
param_name Specifies the parameter name associated with the target in ASCII format.
Default
N/A.
Usage Guidelines
Use this command to delete an entry in the SNMPv3 snmpTargetParamsTable. This table specifies the message processing model, security level, security model, and the storage parameters for messages to any target addresses associated with a particular parameter name.
The following command deletes a target parameters entry named P1:
configure snmpv3 delete target-params P1
The hex_param_name parameter was added in ExtremeXOS 11.0.
Platform Availability
